DistortedVision
I've asked on another forum but I'm going to ask here as well. We have a 16 year old Glo-worm Hideaway 28kW regular boiler with hot water cylinder, cold water cistern and header tank.
I preferred to have a combi boiler and this is what nearly every installer had recommended. I was going to go for a Worcester Bosch 440CDi Highflow and the best quote I've received is £3400 cash from an approved WB installer and hence comes with a 6 year warranty. The installers on the Ultimatehandyman forum said that is ridiculous. Most said I should get a system boiler and a 200 litre unvented hot water cylinder instead. We have two bathrooms (one main and one ensuite). Only the main has a bath in it but its never used. Both have electrical showers but a thermostatic mixer valve shower is going to be installed in the main bathroom when its renovated next year. Its a 5 bedroom house but there are only 3 people living here. They are 12 radiators in total. My main concern is the DHW flow rate. The professionals on the other forum have said that the flow rate on the Highflow models is poor after the 60 litre heatbank has been depleted. Also they said the build quality of WB is poor in general. The consensus viewpoint on there was that if I should go for a combi I should get a Valiant 837. Personally for cosmetic reasons I would prefer to get a floor mounted rather than a wall hung one but its not critical.
I have been looking at non mass market boiler manufacturers like Veissmann. I had an approved installer come round yesterday and he in fact said Worcester Bosch, Valiant and Veissmann were all good and of equal quality. I was looking at the Veissmann 222-F as it has a large 130 litre heatbank. But the installer said we neither had the DHW requirements to justify installing one nor the plumbing infrastructure. All the pipework in our house is 15mm and he said it would need to be upgraded to 22mm to achieve its full performance. I admire him for his honesty.
Here is the breakdown of the Worcester Bosch Quote:
Many thanks!
- Add Cleanser to the central heating system prior to works commencing.
- Drain down and remove the existing Glow-worm Hideaway central heating boiler.
- Drain down and remove the existing hot water cylinder, cold-water tank and header tank.
- Supply and install a Worcester 440 Cdi condensing combination boiler above the existing boiler position.
- Run a new 28mm and 22mm gas supply from the garage in the exisiting boxing to the new central heating boiler.
- Supply and install a TD 200 plug in programmer.
- Supply and install a TD 10 room thermostat.
- Supply and install all pipe-work and wiring.
- Brick up the existing flue.
- Tile the floor area beneath the existing boiler position to allow the new jig to be fitted.
- Supply and install new chipboard to the area beneath the existing tank positions in the loft area.
- Fill, test and commission the central heating.
- Add inhibitor to the central heating.
Many thanks!
