W
wongo
My CH system consists of a Potterton Suprima 60 boiler, Sunvic 207 Select programmer/timer , Honeywell 4073A 3 port valve Grundfos 15-50 pump on the ground floor with a immersion tank on the 1st floor. I believe it's a pumped CH and gravity HW system. When I switched on HW (with CH off) on the programmer I also get heating. Should I not have HW only without heating?
The programmer/timer backplate has terminals NL1234. There is no wiring connection to terminal 2.
I was told it could be an issue with the Honeywell valve.
