View the thread, titled "Advice on Thermostatic Radiator Valves" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Sonnie2344
I have been asked by my tenants for TRVs to be fitted in the house. There are 8 rooms in the house, 3 are bedrooms, bathroom, hallway (thermostat control), wc, lounge & kitchen dinner. Do all the rooms need TRVs? How much would the work cost to be done by a proffessional?? How much work is involved??
Thanks for your help
fit trv's on all but your bathroom rad/towel rail.
simple job, drain down system, change valves, fill up, bleed.
if the systems not bled properly it will cause complications and a return visit. i would quote a days work to cover my back.
good luck
shaun
Might need to fit a bypass valve too as all trv's are being fitted 🙂
as said leave one rad without trv and will be fine most will quote days work so anything between 150-200 plus the valves
if this is a wall thermostat control Then this must have a standard lockshield Radiator valves.
the problem could be there will be no control of heating temprature and will cause boiler to over run heat.
Reply to the thread, titled "Advice on Thermostatic Radiator Valves" which is posted in UK Plumbers Forums on Plumbers Forums.
