View the thread, titled "Advice on turning off water from Hot Water Cylinder in Townhouse" which is posted in Bathroom Advice on UK Plumbers Forums.
J
JimONE
Hi there,
I need to replace a washer on the mixer tap in our kitchen. Would be much appreciated if I could get some advice on the correct way to turn the water off / on. I live in a 3 storey townhouse, the kitchen is on the 1st floor and the Hot Water Cylinder is in the airing cupboard on the 2nd floor.
– When I turn the water off from the mains, which valves do I need to close off on the HW Cylinder? There are 3 on pipes connected to it and I'm not sure which ones I should be locking off – see photo attached. 1. and 2. are warm and 3. which is hidden at the back is cold. There is also a pump above valve 2. which I guess is there to help move the water up and down the house.
– Once water is off. Should I just drain the residual water from the kitchen taps to replace this washer? or drain the bathroom taps and utility sink also?
– When I've replaced the washer, should I leave the taps open when I turn the water back on to prevent any air getting in the pipes?
Many thanks in advance
J
hi jim.
you need to be looking for a 22mm/28mm pipe coming down from the cold tank above, and feeding to the bottom of the hot cylinder. the pipe at the back looks to be the one, what is the 3 pointing to??
more/better pictures needed.
when you have found the right valve being able to turn it is another issue??
is there no isolation to the mixer tap pipes?
Looks like no3
Close that one.
Go to the kitchen sink and open the Hot tap.
Go to the bathroom and open either the bath or basin tap to let air in, you'll then get more water drain out at the kitchen sink.
Change the washer close the kitchen hot tap.
Upstairs, close any other taps you've opened.
Open the valve no 3.
Go to each hot tap in turn and open slowly till water flows then close.
hi jim.
Hi Simon,
Thanks for coming back to me, 3 in the original photo is pointing to the valve at the back, you're right, I can't turn it – some WD40?
Some more photos attached. Some showing pipe behind HW cylinder and some underneath sink. I can't see any isolation to the mixer taps. There is a small blue tap running from the cold pipe – but the pipe running directly off it goes to the dishwasher.
Cheers
J
hw1.jpghw2.jpghw3.jpgundersink4.jpg undersink1.jpgundersink3.jpgundersink2.jpg
be careful if you do start going a bit heavy handed on valve 3, they can drop so you cant open them again (sometimes). just turn the cold mains off and drain the loft tank aswell.
Sorry, this may sound daft, but I'm new to this.
Do you mean turn the cold mains off and then turn on the hot / cold water taps in the house, until both the loft tank and the HW cylinder drains (not touching valve 3)? Then I'm ok to replace washer and re-fill the system.
(Obviously with the HW heater is switched off)
Thanks!
J
Buy a referb kit £14 ish. Turn of cold mains open all cold taps. Change guts. Now your familiar turn on all hot taps and just do hot with a bit of water coming out. No air locks no issues and beautifully working taps
(Obviously with the HW heater is switched off)Thanks!
if the cold main coming into the house is turned off, then yes open hot taps and you will empty the cold water tank that feeds the hot cylinder, dont worry about the heating, that is separate.
the hot water cylinder will still be full, it is the cold tank that would empty albeit through the cylinder,
thus using up any hot water.
when the cold tank is drained you then would be in a position to also swap the seized up gate valve
Looks like no3
Close that one.
aaaaannnnnndddd AIRLOCK!
In the bottom left corner of the 4th picture there seems to be 2 isolation valves. It isn't clear what these are for but may be a simple way around the job. Try giving the slots in them a quarter turn and check if that stops the flow from the kitchen mixer. I suspect it will.
Reply to the thread, titled "Advice on turning off water from Hot Water Cylinder in Townhouse" which is posted in Bathroom Advice on Plumbers Forums.
