View the thread, titled "advice on wiring ferroli external thermostat" which is posted in UK Plumbers Forums on UK Plumbers Forums.
N
not a clue
hi peeps just in the process of fitting a wireless external thermostat do i need to disconnect the loop which is fitted to the wiring it has remove to fit the clock on a little tag but not sure if thats only if you use the built in clock or do i leave connected 🙄cheers
on a wireless room stat,just take out stat,link,cable
on a programmable room stat again take out stat,link ,cable,leave internal timeclock set perm on
Reply to the thread, titled "advice on wiring ferroli external thermostat" which is posted in UK Plumbers Forums on Electricians Forums.
