View the thread, titled "advice wanted with plastic pipe fitting" which is posted in UK Plumbers Forums on UK Plumbers Forums.
T
tomj
hi all just want a bit of advice please, im running a new jg plastic pipe lines hot and cold due to refitting bathroom, i want it to go through the joist as this is the most direct route to the mains but they will pass over a halogen light fitting that is recessed in the ceiling below, will it be ok to do this or do i need to cover it somehow, pipes are jg speedfit barrier pe-x 15mm and are around 30mm above the light hope i have included enough info,thanks
will melt, found out the hard way. feed a pipe in a loft under the boarding week late , new shower!
I Agree with their advice.. find another route, away from the light. if it's plastic and it's near anything that's heating, it'll melt.
i think that there needs to be a minimum of 150mm clearance of light fittings for plastic pipe
Reply to the thread, titled "advice wanted with plastic pipe fitting" which is posted in UK Plumbers Forums on Electricians Forums.
