View the thread, titled "Air bleed magnetic filter" which is posted in Boiler Advice Forum on UK Plumbers Forums.
Can someone please advise how to bleed air from a magnetic filter installed on a Worcester Greenstar boiler. I don’t want to clean it out as that was done by a professional engineer who seemingly left me with this problem. Specifically, should I close the valves either side of the filter before opening the top bleed valve? Should the boiler be turned off? Etc, etc
Comments appreciated.
What type is installed and what’s the problem?
I have attached a pis of the filter. The boiler is making sloshing noises despite having bled all radiators three times. So I assume the air must be in the filter.
Reply to the thread, titled "Air bleed magnetic filter" which is posted in Boiler Advice Forum on Electricians Forums.
