M
morty
hi all,
a simple query for you.the bleed screw on the incoming pipe to the coil in the cylinder is leaking,so i thought no problem i'll change it.the problem is that i can't find anywhere on the system to dump the initial pressure the water will be under and lets say in the past i've had the unfortunate experience of standing next to someone undoing the pipes to the coil when changing the cylinder & been showered with several litres of water under pressure.it's an indirect system and i can't believe theres no way release the pressure except for cracking the pipes???
thanks for your help in advance😉
