View the thread, titled "Air in my system Advice Please" which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
R
Ratters
Hi guys have an old open vented system. I have lived in the house for 3 years and have always had some some air in the system. A few weeks ago I decided enough was enough. So I took every rad off and flushed them through. Then flushed the system through with Sentinel X400 system restorer and filled the back up with and put 2 lots of sentinel x 100 inhibitor in.
While the air is now reduced and I did remove lots of black sludge I am still getting air in the system.
Any suggestions would be gratefully received.
it may be possible that if the pump is located close to the vent pipe and f/e tank, it could be drawing air down and into the pump/system when heating is kicking in.
since you have a lot of corrosion in your system which coincides with air in system, i assume the ports of the pump will be heavily blocked and corroded/. take of and eliminate.
"it may be possible that if the pump is located close to the vent pipe and f/e tank, it could be drawing air down and into the pump/system when heating is kicking in"
If this is the case what do I do about it?
which boiler have you got easiest solution may be to seal the system
first takeof the pump and look inside for heavy corrosion and restriction of the ports, a good sign of air intake from the exp pipe.
if so, look to replacxe pump, lift f/e tank and exp pipe higher to eliminate air intake.
thats my solution, if anyone can add to this.?.
Reply to the thread, titled "Air in my system Advice Please" which is posted in Air Sourced Heat Pumps Advice Forum on Electricians Forums.
