View the thread, titled "Air in system - bad design?" which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
Bunker
Im mainly a oil boiler service engineer but do get involved in systems sometimes. I was asked to look at a system which is constantly full of air, always bleeding some of the rads. In the loft I found the expansion pipe to be gurgling and Im sure it was blowing and sucking.
Looking at the design (see below) there are a few concerns, but its not really my thing:
Im concerned that the pump will be dragging air in from the expansion pipe.
Im concerned that the hot water primary return is only 15mm
Will air be getting in at the pump valve leaks?
Btw, missing from the photo is a manual air vent in the HW flow.
Its a small 3 bed house.
Any comments would be welcome
Needs converting to a close couple feed and vent arrangement. It will keep dragging air down the vent with that configuration.
Agree. Have been to a job where gravity primaries have been made pumpd but they hadn't alterd the cold feed and vent, was pumping over like a gooden.
I 'fixed' this job back in feb by combining the F&V up in the loft (on the 22mm), I also fixed the leaky pump valves, but have just heard from the managing agent that the tenant still needs to bleed the bathroom radiator once a week. All other rads are fine now. When I first went there, I put a match to the air in the bathroom rad (not towel rail) and it didnt ignite so assumed it was air. Is it worth sticking one of those auto bleed rad valves in? Not sure what else to try.
Reply to the thread, titled "Air in system - bad design?" which is posted in Air Sourced Heat Pumps Advice Forum on Plumbers Forums.
