View the thread, titled "Air In System Open Vent Combi Attached" which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
shortcircuit
What is the correct sequence of connecting water up to boiler after it has been off and drained
Check all drain-offs are shut & air vents closed before re-filling!, depends what type of system you have also, is it a sealed system with pressure gauge or a tank fed system?
Tank fed CDi, the system will fill once you turn the cold mains back on so make sure all your rad bleeds are shut B4 you turn the cold on. Then fill the system as you would any other open vented system IMHO. You do know how to do that yeh? 🙂
Reply to the thread, titled "Air In System Open Vent Combi Attached" which is posted in Air Sourced Heat Pumps Advice Forum on Plumbers Forums.
