Open vented system with a gas back boiler. The upstair radiators are hot a part from two are cold. There is still air trapped in the system. I've flushed it out several times even by capping off the f&e vent pipe and attaching a hose to the drain valve to disturb the built up of sludge and I've filled the header tank with system cleaner and bled all the bottom radiators then the upstairs now only two that are upstairs are filled but cold? I'm going back in a few weeks later to flush the system out and hopefully it was only a build up of corrosion in the pipe work.
The two cold radiators up the stairs have been manually flushed out and new trv valves been replaced.
There is a aav in the loft, could this be sucking air in? Maybe replace for a new one?
I'm kneeling for your knowledge and expertise would be more than appreciate?
