View the thread, titled "air in water supply" which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
sasikahlon
My customer have an unvented hot water cylinder (Ariston). They reported that when they run hot water out of any hot tap at the house there will be quite a bit of air coming through too. It's a bit like when you run the cold taps after the system was drained down.
Is anybody know what could be the problem and how come there is such a build up of air in the unvented cylinder.
Ps This is not a new installation, the cylinder was fitted 10 years ago and the air problem only started recently.
Reply to the thread, titled "air in water supply" which is posted in Air Sourced Heat Pumps Advice Forum on Plumbers Forums.
