unfortunately have to change rad valves.......
seen your thread now - many thanks
cheers
If you don't bung the feed/vent and drained down and airlocked when refilling from gravity, fill from the mains attached to the lowest drain off, forcing the air out as it fills.Hello All
I'm looking for some tips on dealing with air locks after a radiator change on a fully pumped vented hw/open ch system.
Are there any good ways to prevent/minimise this??
How best to deal with an air lock on such a system??
Thanks in advance
Cheers
RSR
Reply to the thread, titled "Air Lock - Best Practice/Prevention ??" which is posted in Air Sourced Heat Pumps Advice Forum on Electricians Forums.
