R
Radioman
I have a repeat call back to a propert where after 4 to 5 weeks the hot stops flowing. All I do is back flow mains cold through a kitchen mixer and bingo it works. But what's causing it? We have 50 gal coffin tank in loft new 48 inch hot cylinder , triton power shower in en suite leccy shower in master fed from Teed off cold supply to tank, bath bog and basin in master. Only 2 occupants. Vent is clear all gates replaced with full flow ball lever, supply tank ball valve replaced. Tenant assures me only 2 residents living in.
My theories are. Supply of mains cold in the house is 15mm so when leccy shower running tank main is starved causing drop in level. Power showered is then run at same timecwhich drops level further causing low flow in hot due to no water in loft tank.
Or tenant is turning boiler and tank stat up causing a problem there. Any ideas
