G
gmx
Hi all
This is my first post on the forums so please be gentle 🙂
I am wondering if anyone can help with an issue I've got.
I'm willing to call in the professionals but would like to see if this is an issue I could sort myself, and learn in the process.
We have a open-vented system with an Ideal Icos boiler.
I had to remove a radiator for decorating but unfortunately the TRV was faulty and wouldn't shut off the flow.
I tied up to ball cock in the tank, drained the system at the drain just above the boiler, and fitted the new TRV.
On refilling the system, I went around and bled all radiators and the pump, until no air was escaping.
It's worth noting that all radiators in the house are currently turned off due to an anomaly in the setup of the system whereby we only get hot water via the heating. We have inherited this "feature" and it's on the to do list.
Anyway, on firing the system back up the boiler kicks in and the burner light goes solid, but then pretty soon (ie: 5-10 seconds) there are loud clunking noises from the pipes above the boiler and shows status code "H A".
I have tried re-bleeding everywhere and there is no air coming out of any radiator or the pump.
However, if I open the drain above the boiler (where I drained the system from), there seems to be air mixed with the water which I can feel in the hosepipe attached and see if I put the end of the hose underwater in a bucket.
It's worth noting the radiator I removed is still off, with the new TRV in the closed position.
Can anyone please assist in troubleshooting this issue?
Many thanks in advance
Greg
(p.s the system was working before the drain so please don't just tell me to scrap the Icos boiler! 🙂 )
Greg
