View the thread, titled "air pressure fault.?" which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
Biggal5
Hi all, could do with some advice on a fault I had earlier..? Much thanks in advance:
Customer has a worcester 28Si combi, paper work says installed about 7yrs ago although they only have property for 3 yrs or so,
I'm finding a fault on the air pressure switch/fan area. All is fine when the c/h system is up and running, works all good... when the hot tap in the kitchen downstairs is turned on, within a minute the indicator shows a fault on the air flow? I leave the tap running to see the results and the fan shuts off for 5 mins, then burner starts up again for 1-2 mins before shutting off again for 5 mins. It seems to cut in and out like clockwork; off for 5mins on for 2mins....
I've done the same for both the bathroom basin and bath but no problem there? The fan works fine for c/h so i believe the fan is fine, i've tested pressure switch and cleaned the hoses and all good there i think. I've also checked the flue for blockage but seems like none there either?
Any advice please? Much appreciated.
Reply to the thread, titled "air pressure fault.?" which is posted in Air Sourced Heat Pumps Advice Forum on Plumbers Forums.
