View the thread, titled "air pressure fault.?" which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
Biggal5
Hi all, wondering if I can get some advice on a fault I had earlier...
Customers had a worcester 28Si combi installed at least 3yrs and all gong fine until recently. C/H system works fine and well, no problems.
When hot taps are turned on the indicator light shows an air flow fault on either air pressure switch, fan or flue? Within a minute of taps turned on fan cuts out for 5 mins. I've left the tap on continuously to see the results and after 5 mins the burner lights up again for 2 mins? then out for 5mins. works like clockwork with 2 mins on then out for 5 mins...
The fan works fine with c/h system on so i don't think the fan is faulty, also i've checked the air pressure switch and cleaned the hoses and also checked the flue for blockages but none there as far as I can see?
Any advice on what the problem could be please? Baffled as fault only on DHW system?
Many thanks in advance.
Reply to the thread, titled "air pressure fault.?" which is posted in Air Sourced Heat Pumps Advice Forum on Plumbers Forums.
