View the thread, titled "air pressure switch question" which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
Personaly I only fit like for like. You will come across lots of parts that will fit other boilers but your running the risk. At the end of the day, you can sleep at night knowing youve fitted the correct part as per the manufactuerers instructions. IMHO
Reply to the thread, titled "air pressure switch question" which is posted in Air Sourced Heat Pumps Advice Forum on Plumbers Forums.
