View the thread, titled "Air pressure switch" which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
lordyjordy111
Hi again
general question on an air pressure switch/fan operation
attended a course the other day, just reading through my notes but not sure if i've got this right
If the air pressure switch is stuck closed and you try to fire the boiler, the boiler will not run the fan as it has sensed that the switch has made before the fan has run.
is this correct??
cheers
Reply to the thread, titled "Air pressure switch" which is posted in Air Sourced Heat Pumps Advice Forum on Plumbers Forums.
