View the thread, titled "Airing Cupboard Being Missed" which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
R
Radioman
After a successful conversion to a combi in one of my properties my tenant is missing the use of the airing cupboard where the cylinder used to be. They used this to dry their towels etc. Now they have damp towels that end up smelling like a Tom Cats pants. Any suggestions on how I can warm up this cupboard?
So I think I will fit a normal rad. I could fit an elec element into that like a dual fuel towel rail but surely if I do that and leave the valves open during the day won't the element try and heat the rest of the house up? I could end up with a shocking leccy bill[emoji21]
Element will fit towel rail, not standard radiator (as pointed out by Scott).
Also, whole house will not be heated, only the towel rail to which element is fitted
For old ladies that have come off solid fuel and have the AC judders we fit an two port on house and use old primaries to get a rad up to AC. 6*6 single with prog stat. Two L/s and that's it. It acts as bypass and can be set to be on 24/7 should they wish. Doesn't effect the Gaffs heating.
Removal of damp air..... Explair with humidity sensor
It's a combi
Why cant the people get themselves a tumble dryer. and a clothes airer. rather than having piles of stinking wet washing around the place. gross
A++ isn't the best for environment. Our a++ is less efficient than a beko band b. Read the actual performance spec. Someone told me.... Thought b.s till I checked
Reply to the thread, titled "Airing Cupboard Being Missed" which is posted in Air Sourced Heat Pumps Advice Forum on Plumbers Forums.
