K
kay-jay
right ive got a problem after draining and filling a combi heating circuit to change a faulty rad valve.
ive never had an airlock before on combi systems, but anyway the problem is that after all rads bled, all work as normal apart from one on the ground floor which only gets luke warm.
could this be an airlock? and if so whats the best way to clear it? like i say ive never had an airlock on a combi sealed system before after bleeding! only on open f+e systems, which i generally cure by turning all rads off apart from the one with the problem and the pump clears it. will this work on a sealed system via the air vent? or do i need to do something else? would prefer not to drain down again if possible as i added an inhibitor to the same system.
thanks in advance
KJ🙂
thanks in advance
KJ🙂
