View the thread, titled "Alpha 240e hot water issues" which is posted in Bathroom Advice on UK Plumbers Forums.
douggie
hey im trying to fix an alpha 240e hot water only works when heating has warmed up it sends the flow round the heating all the time i belive it is the diverter stuck is there any way i can prove this before i buy a new one i striped it down last night and not knowing wat a good one should look like or move like was at a bit of a loss can i repair or do i need to buy new one if that is the prob any help ideas most appreciated thanks
Depending how old the Alpha is, you could probably get away with a divertor valve recon kit, as long as the DHW heat exchanger isnt blocked or scaled, if your reconing the divertor, replace the HW diaphragm at the same time!!!
Reply to the thread, titled "Alpha 240e hot water issues" which is posted in Bathroom Advice on Plumbers Forums.
