dave1066
On Sunday I discovered my Alpha CB24 had no power. On inspection, the main terminal fuse had blown. With a bit of trial and error I found that disconnecting the fan from the circuit board and replacing the fuse powered the boiler back up. So I replaced the fan Monday. Everything worked fine for a night and day, then on Tuesday evening done the dishes and we had hot water. Then 10 mins later go to run my daughters bath and theres no hot water. When you turn on the heating or run a hot tap the boiler makes a noise like its trying to do something and then the yellow and red indicator neons start flashing together.
Please can anybody help?
