Hi Graham ...not ruling out pcb but alternate flashing tends to be low pressure switch ... did you test for 24vDC at the switch connections as per mi's? If voltage not there then to doublecheck you can temp link the switch wires out? .... Still most likely PCB from what you say though 🙂
Reply to the thread, titled "Alpha CB24 problem" which is posted in UK Plumbers Forums on Plumbers Forums.
