Alpha cb28 boiler pressure increases.
View the thread, titled "Alpha cb28 boiler pressure increases." which is posted in Boiler Advice Forum on UK Plumbers Forums.
steve1905
We have a problem of the pressure building up on our boiler. I need to release the pressure twice a day (via a radiator) . My first port of call was to check the filling loop, which has been left on the boiler. I removed one end of the filling loop, undoing it from the cold water feed side. There was then a steady drip of warm water from the filling loop hose coming through. I put the loose end of the filling hose in a bowl to drip and gradually the pressure in the boiler drops. I turned off the supply of cold water to the boiler, with the filling loop in place both ends and the pressure remained constant. I wonder if anyone could help with a possible diagnosis of the problem ? Thanks for any help
Sounds like there could be a leak on the hot water heat exchanger between the mains water and the heating.
Reply to the thread, titled "Alpha cb28 boiler pressure increases." which is posted in Boiler Advice Forum on Plumbers Forums.
steve1905,
Dotty,
