Hi Guys,
called to investigate an intermittent 'no hot water' on the above so went armed with a new clip on microswitch thinking nice quick job to end the day. Wrong! Opened tap and pulled switch off boiler fired fine so me thinks diaphragm as pin seemed not to be moving. I've overhauled diverters before so no problem there. The problem which bothers me is that the plate HS gets hot, very hot, when the hot tap is opened but the water flows cold. Can anyone explain, 1. how the plate HS can get stinking hot but the water flows cold and 2. the pin from the diaphragm isn't moving to operate the switch but is diverting the primary flow. When the tap is closed the plate HS cools down so not a stuck valve! I'm assuming this is simple diverter where the pin from the diaphragm operates the flow switch and also activates the diverter valve plates. Anyone noticed this before with a simple diaphragm perforation? Thanks in advance.
