View the thread, titled "Alpha cb28x red led burner light failure" which is posted in UK Plumbers Forums on UK Plumbers Forums.
W
Wills2296
Hi can someone give me some advice please,
I've got 5-6 year old alpha cb28x. I've sent the pcb away recently as the fan was failing to start and came back repaired and worked fine.
but now keep getting a solid red led, failed to light, I've got 230v from the gas valve terminals but the valve is intermittent. Does this sound like common problem, I'm thinking new gas valve but could it still be the pcb causing this
many thanks
This plumbing forum will not provide advice to anybody with regards to boiler repairs or any other form of gas plumbing without you first providing us with your Gas Safe Registration number in a thread - for very obvious reasons. If you're not qualified to touch gas, you should stay well clear of trying to!
Thread closed
Reply to the thread, titled "Alpha cb28x red led burner light failure" which is posted in UK Plumbers Forums on Plumbers Forums.
