View the thread, titled "Alpha cd32c hot water for 10 secs" which is posted in Bathroom Advice on UK Plumbers Forums.
DAZZA6432
Hi all
i had a problem with the bolier indicating 2 fault lights A flashing B continuosly, stripped down the diverter valve and removed some hard limescale, cleaned out, refitted valve and now heating is sound only problem remains is when i turn on hot tap boiler ignites but after 20 secs the same fault lights return, turn off tap and boiler returns to normal after 30 secs???????????? would appreciate any advice.
thanks
:welcome: dazza to the forum🙂
Initialy it sounds like your plate heatex may also be "scaled" up? Do you live in a hard water area?
Yes i do,could the dhw heat exchanger or hot water outlet be partially blocked?
If you're saying "yes I do.." to living in a hard water area and you have discovered Scale within the diverter section in all likelyhood it will also be throughout your domestic water system, plate heatexchange included.. Do you have any scale reducers fitted?
Don't rule out other possible's such as sensor faults etc. By-the-way ... this is just one possibility 🙂
Reply to the thread, titled "Alpha cd32c hot water for 10 secs" which is posted in Bathroom Advice on Plumbers Forums.
