P. R. GRANT
Please can somebody tell me what the correct settings should be for my Alpha Combi Boiler Eco 2 Plus and Thermostat.
Please see the attached photograph with all my current setting.
Currently, my daily electricity usage seems to be higher than normal and it just was serviced.
kind Regards
Mr. Grant
Seems perfectly normal working conditions, it has been cold recently and your boiler has frost protection, if the outside temperature drops below your 7.5, the boiler will run for short periods to warm it through to prevent freezing. The servicing should make no difference.
  • Winner
Reactions: P. R. GRANT
Your boiler uses very little electricity. It’s gas.
You are using more electric, because it’s darker and your inside more,
stop looking daily at your smart meter. It will drive you mad.
  • Friendly
Reactions: Stu-B
