dougal
hi all
just after second opinion
has anyone has a fault with a and b flashing at same time. only thing working is pump. checked continunity across low water pressure switch, continunity on over heat stat and fan stat. checked air pressure switch isnt stuck ie with no demand theres no continunity on two gey wires on air pressure switch, so its not stuck open. as theres no voltage to fan, it can only be p.c.b
dont have manual not experienced with alpha fault codes.
many thanks
many thanks
