Dennis
First, Hi all. Newbie here!
I have an eight year old Alpha SY24 system boiler that powers my house and an annex on two feed and return loops, both controlled by a seperate programmer. Until recently this system worked like a dream.
We then started to encounter problems which were diagnosed to a faulty water pressure sensor, which was replaced about two months ago. Since then, the system has degraded until virtually no heat or hot water.
After some elimination it looked like the pump, so telephone for the cavalry.
Cavalry arrives, hour or so later diagnoses pump problem, will return the next day to replace.
Next day, as promised, pump replaced with a similar, but not identical one. No change to system. New diagnosis - auto air vent blocked by sludge, pump maybe cavitating.
Next day, replacement air vent fitted, no change to system. New diagnosis: heat exchanger blocked by sludge.
Two days later, heat exchanger removed, cleaned and replaced. System now 'OK' but may take 'two or three days to get up to heat' [wtf?]. This comment was apparently based on my remark that [when the system was degrading rapidly] after a drain and refill it could take that long for the last radiator, very prone to airlocks, to clear and heat.
So, final diagnosis. The system is now working but needs a sludge clean and a magnaclean installed for which a quote is being prepared.
I do not disagree with anything in this comment, except the 'system working Ok' bit...
We have no heat. No hot water and the boiler repeatedly indicates a pump fault.
Sorry for such a long post, and I am sure that I have missed lots, but does this sound familiar to any of you guys? Any thoughts?
It's cold and I stink, as do the rest of my family...🙁
(not really true, it's only me...)
