View the thread, titled "Alpha sy9-24 low pressure" which is posted in UK Plumbers Forums on UK Plumbers Forums.
bedek
I've turned of my gas boiler for a week and now it shows alert that pressure is to low (A and B blinks)
How can I re pressure Alpha sy9-24 gas boiler ?
In the instruction on page 15 there is information that I need to "Open the fill point valve on the filling loop until water is heard to flow" which is fine but do I have to connect that filling loop to the boiler ? if so then would that be ok to connect hose from the tap to the inlet marked red on the attachment ?
Regards,
Adam.
Thats a drain point on the boiler, you should look for a metal braided hose this connects to two pipe with maybe black handles
As I understand the metal hose you mentioning is the filling loop ? I so the in the instruction for the boiler there is information that it should be disconnected after filling the boiler - see "Screenshoot 1".
Later in the instruction there is information how the system should be filled - seen "Screenshoot 2".
My question is - if I buy such filling loop hose where should I connect it ? please find attached photos "boilder--..."
I can not add link to the full instruction as it is blocked on this forum 🙁
Reply to the thread, titled "Alpha sy9-24 low pressure" which is posted in UK Plumbers Forums on Plumbers Forums.
Thread Information
Title
Prefix
N/A
Forum
UK Plumbers Forums
Start date
Last reply date
bedek,
Alpha man,
