View the thread, titled "Alucard" which is posted in The Welcome Wagon :) on UK Plumbers Forums.
My Central Heating system has a Plumbright Magnetic Filter 22mm installed. The filter body has a drain valve on the bottom with a seal cap. This 360 degree drain valve can be rotated to allow operational access.
Q1 - How does the upper 360 degree part of the drain valve seal and still allow rotation?
Q2 - How does the drain valve end seal against the filter body?
Q3 - How to seal the filter body to the 360 drain vslve?
Looking inside the filter body there is a hexagonal Allen wrench acces; which is larger than 1/2", with no visible seal below it. This also has approximately 1mm of vertical movement of the 360 drain valve, is this normal? As this is the leak point.
Q4 - Is it necessary to replace the large body O-ring every time it is opened or can it be reused?
Looking forward to some good technical support and practical advice.
Reply to the thread, titled "Alucard" which is posted in The Welcome Wagon :) on Plumbers Forums.
Alucard,
