L
LAM
Could someone help please? I have just moved into a flat that uses the Heatrae Sadia Wet Electric heating system for heating and hot water. It's proving very costly at around £100 per month and it's a huge unit (about the size of a fridge freezer) that sits in the middle of my kitchen/dining room. Although the flat is small, it is an old property with high ceilings. It is also a listed building which means I can't have a flue on any of the outside walls. Can anyone offer an alternative option that a. is less costly to run and not too costly to install and b. is not as large and unsightly. The thermostat is also broken and I would be keen to know of any smart thermostats you could recommend that work with electric heating systems. Thank you in advance and for taking the time to read this.
