I was going to ask the same thingSo how do you connect to appliances as there’s compression fittings on them
Every job every day, im 58. Lost count of times ive gone back on pretence of leaving spanners behind. Never found a loose one yet mind, or a flue inspection cap.Just me or anyone else drive away from a job and worry if you tightened all the nuts?
All the time. Just gas safe registered but always get home and overthink what I’ve done! Always do a tightness test and then relight appliances just before I leave but still get home and stress.
Hopefully it gets better, any tips?
Like it good excuse to go back and checkEvery job every day, im 58. Lost count of times ive gone back on pretence of leaving spanners behind. Never found a loose one yet mind, or a flue inspection cap.
Yep many times on occasions even gone back to double checkJust me or anyone else drive away from a job and worry if you tightened all the nuts?
Correct attitude ...Gsr engineers are more responsible for the publics safety than the over paid GP docter who just shift the problems on to someone else but get £100,000When I was an apprentice, long before mobile phones existed, when even Corgi was voluntary, it was my responsibility to do the tightness testing. I got back to the office with my fitter only to be told by the boss, that the client had phoned the office, to say we had left something connected to the gas meter, oops. The boss glared at us, and his comment was "at least it proves you're bothering to test your work", and believe me, back then not everyone did. Ever since that day I have been paranoid about testing, so I check and re-check, and always have a last look around for tools.
Nothing worries me as far as work goes.
More important things to concern the old grey cells.
After all works work.
Nope. But they can lock you away.As my old boss once told me when I was starting out "At the end of the day, they can't shoot you."
I like that one. Gas Engineers are in a bit more of a serious position but even then they still can't actually shoot you if you do something terrible.
At least you admit it mate.On one of my first plumbing jobs (fitting a kitchen mixer tap) I tightened up the tap connector to the copper pipe fitting and thought 'have I nipped that up enough?`and the customer phoned the next day describing a puddle on the floor, I returned immediately and nipped it up, moral of the story? Im a ****.
OCD may cost you a little more time but it’s better that than being over confident and just assuming everything will be ok all the timeMy nephew is a plumber working on gas too, he's very talented but unfortunately suffers terribly with ocd, worrying about jobs he's done immaculately but still worriess terribly, high pressure job hey.
Reply to the thread, titled "Anyone drive away from a job and then worry about if you’ve forgot to tighten any nuts" which is posted in General Plumbing Jobs Discussion on Plumbers Forums.
