I have the below instantaneous water heater which is showing an f5 fault. I cannot find installation instructions for it any where and client doesn't have. So called glowworm who say they cannot help either. Said part's are not available for it anymore. So any ideas guys?
APS not fan, is it a 2 wire or 3 wire?
I didn't see an overheat stat:clown:
I am getting continuity through the switch when I suck on the tube. When you say reading on switch, what reading do you mean
I didn't check the aps for resistance. I always believed you just test for continuity
Venturi fine. But the fan is not getting 200volts going to it so that makes me suspicious of pcb
Are you checking fan voltage at the board or at the fan have you checked the fan wiring loom for continuity?
by the sounds of what your saying i would edge towards pcb if not getting 240v at fan and your saying aps is fine. let us know what you decide on and how it turns out. Good luck and sorry cant offer anymore advice.
Reply to the thread, titled "anyone worked on many heatline products before..." which is posted in Gaining Plumbing Experience on Plumbers Forums.
