After some advice about flux, and also to see which fluxes others are using. Are some fluxes easier to use than others? Do some give you more time to make the joint before evaporating? Laco and Powerflux seem to run down the pipe very soon after applying heat.
Also, what are the different types of flux - some seem to be water soluble (Laco) and other grease based (Yorks. traditional)? What are the advantages of each?
The main fluxes seem to be Laco, Powerlux and Everflux. Less common ones are Yorkshire Traditonal and Fernox Fluxite and a real rarity is Templars Telux.
Pegler Yorkshire -
Fluxite
Templars Templars Telux Flux - Templars from JTM Plumbing Limited UK
Pegler Yorkshire -
Fluxite
