Guest viewing limit reached
ariston 32microgenus dhw problem
View the thread, titled "ariston 32microgenus dhw problem" which is posted in UK Plumbers Forums on UK Plumbers Forums.
G
GAZZA19
hi all looking for some advice on the above boiler i was called to property with hot water problem, customer said last person had changed the aps on it, when i tried bolier it worked fine then i tried again and nothing the light on the microswitch inside boiler did not light only lite when i knocked water off and on quickly on kitchen tap there as been no fault code coming on boiler at all ?? some advice would be grateful thanks:smiley2:
The only way i get onto it is to go on the forum page, click on gassafe register one then click on the private gsr forum sub thread.. Long winded but i am thick.
not sure about those boilers, is it a standard diverter valve with a pin and micro switch attached.? if so it sounds like the diaphragm is knacked or the pins sticking. if its easy change the diaphragm if not price for a diverter, if thats the case.
Nah these don't have a diaphragm for the h/w. I believe there is a turbine which rotates a little magnet which activates a sensor, the turbine is probably buggered. Unless I'm thinking of the wrong boiler?
Reply to the thread, titled "ariston 32microgenus dhw problem" which is posted in UK Plumbers Forums on Plumbers Forums.
GAZZA19,
bewsh,
