View the thread, titled "Ariston Clas HE sp1 intermittent error" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Sim77
Hi guys,
I got a boiler to fix (Have not been to see it yet) - customer reports it is showing an intermittent SP1 error code (Ignition attempt failed).
I fixed one of those a while ago with SP1 and 501 codes and it turned out to be a PCB.
What is your experience with those boilers? I am aware that PCBs were crap on those and got upgraded later on. Is it usually PCB on those?
S.
I am aware of that JTS. Problem is that with intermittent faults there is only so much you can do and with certain types of boilers there are known faults hence my question: what is your experience with SP1 error on this boiler?
Just had similar fault on another make of boiler , sometimes it would work for days other times an hour or so, flame sensor faulty, could be worth a look if they haven't been changed , how old is boiler ?
Reply to the thread, titled "Ariston Clas HE sp1 intermittent error" which is posted in UK Plumbers Forums on Electricians Forums.
