View the thread, titled "Ariston eurocombi mffi a23" which is posted in UK Plumbers Forums on UK Plumbers Forums.
G
Gazlar85
Some advice please
the boiler has had a new main and secondary heat exchanger and a diaphragm
but still won't maintain hot water temp
when the hot water is drawn the burner fires up and then quickly drops to low then back to high, no modulation in the burner
would this be gas valve or pcb problem?
thanks for any help guys
Hi
The forum cannot give advice on gas appliances that the public can see too.
We have a private sub forum for gas safe registered installers. Loads of great advice. You will need to increase your post count to 10 posts, to make sure your genuine. Then message an administrator with your gas safe number and your in.
This won't get your answer straight away, but will be worthwhile in the future.
Get posting!
Maybe start by introducing yourself?
Reply to the thread, titled "Ariston eurocombi mffi a23" which is posted in UK Plumbers Forums on Electricians Forums.
