M
mantaray
Hi wondered if someone could point me in the right direction.
I have an Ariston Genus 27 BFFI. Have a problem with hot water. When I draw water off from the Hot tap the boiler does not come on. At the minute there is Hot water in the system as the Cental Heating system is working fine also if i turn up heat setting on Hot water side the boiler fires up straight away. Pressure in the system is fine at 1bar. Motorised valve seems to be working as it switches for Central heating.
Does anyone thing it may be the Pressure flow switch?
Would be grateful for your thoughts as need to get this fixed before the good weather comes!!!!
