View the thread, titled "Ariston microgenus 23 mffi" which is posted in UK Plumbers Forums on UK Plumbers Forums.
GasmanxxxR1
No hot water but central heating works
Would i be correct in starting by changing dhw diaphragm
Cheers guys
you would if it had one,if not firing for dhw at all,is the flowswitch on the RH side illuminated?
The diverter valve and flow switch appeared to be on the left hand side, a small red led came on when hot water tap opened
flowswitch is working then,its either the black dv motor or dv its self
assume it does have a diaphragm as i ordered one from pts.
Breakdowns arnt my forte but i want to learn, need to go on some course
Any more advice much appreciated
Reply to the thread, titled "Ariston microgenus 23 mffi" which is posted in UK Plumbers Forums on Plumbers Forums.
