E
exiged
Hi Guys,
Im having an issue with the above boiler and would be very grateful if anyone could shed some light on it.
Wether its hot water usage,thermostat/timer or manual use,The boiler fires up for about 3 seconds then shuts off.The pump keeps on running and i get a red error led lit next to the reset button
but the boiler is no longer heating.
If i press the reset button the boiler fires up and runs fine (sometimes have to press the reset button a couple of times),but can also shut off again after half an hour or so,or if i try using hot water while its running.
First thing i did was try the X800 and X400 chemicals from screwfix for just over a week in the system with no joy.I then had the heat exchange removed and descaled.My rads are now hotter but boiler still showing the sam fault.
There are no strange noises when the boiler is running.Pressure is around 1bar normally and just under 2 while running.(ive tried lower and slightly higher pressure to the same end)
Any ideas guys?
thanks!
Any ideas guys?
thanks!
