M
miked101
Hey everyone, the boiler is leaking from the top of the diverter valve. Water is making its way up past the pin into the top of the valve and then dripping out where the retaining clip holds the motor. Can I just change the bush at the top? is this the correct part?
Seems to be a pretty common issue so hopefully someone on here as had to solve it before.
DV 440 Actuator Bush 998013
the boilers gc number is 47-116-26
Any help is much appreciated.
