Automatic air vent
View the thread, titled "Automatic air vent" which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
L
lenny
Should the cap on and AAV be left loose, tightened or completely taken off when a system has been fully purged?
Len😕
left loose also somewhere for the steam to go if the pump fails(not all boilers have pump pressure switches)
What a load of rubbish, thats partly what pressure reliefs are for.
We don't use automatic air vents anymore as they always leak after a few years.
Once the system has been filled and vented you shouldn't need to leave it open.
Reply to the thread, titled "Automatic air vent" which is posted in Air Sourced Heat Pumps Advice Forum on Plumbers Forums.
lenny,
josh,
