paulcantfixit
Hello,
I have an annoying problem with a back boiler and struggling to get to the bottom of it.
Moved in to a rented house 6 months ago that has a Potterton Fireside 35/51 back boiler.
Over the last month found that when heating hot water only the 3 amp fuse blows in the socket. It is strange as this does not happen when the central heating is on. It started doing it now and again but now does as follows:- turn on hot water, boiler fires, continues to fire, burner goes out as temp reached?, clocks to fire up second time and blows 3 amp fuse.
The house is rented and to be fair to the landlord an electrician came out first and could not find the problem, said it was an earth leak and needed a heating engineer. An enginner has been over but after spending 2 hours on a free call out said it had him baffled.
We have an electric immersion heater and its Summer so the landlord has now decided to drag heals.
If anyone has any idea I would be very greatful.
Thanks.
Thanks.
