O
owington
A neighbour has asked me to look at a radiator that is cold in the middle. I assume this is a build up of sludge so was going to try draining the system and removing radiator to try and blast through with a hose or add some cleaner. When looking in the loft there is only one header tank. When running the hot tap this begins to fill again. Once full i began to drain some water from a radiator and again the header tank begins to fill. There is only one vent pipe and it is a back boiler. Is this normal?
