View the thread, titled "Back boiler with oil boiler, same system?" which is posted in Boiler Advice Forum on UK Plumbers Forums.
Birdingbenny
Hi, I've just moved into a house that has a woodburner with back boiler supplying hot water for both domestic water and heating, two separate circuits so four pipes into the back of the woodburner. There are 5 radiators and the hot water tank has an immersion heater in addition to the coil. I'd like to install an oil boiler connected to both hot water and heating and would like to know if the two boilers can be combined as I'd like to make the most of the back boiler as well. If it is possible, hints and tips would be very welcome.
Many thanks
Hi and welcome along. The best advice would be to get an oftec engineer out to come and assess your set up and to quote for the works.
Anythings possible if you chuck enough money and expertise at it. When you contact engineers for estimates make sure you tell them about twinning the system.
Reply to the thread, titled "Back boiler with oil boiler, same system?" which is posted in Boiler Advice Forum on Plumbers Forums.
