Hi all and thankyou in advance for any advice you can give.
There is a three cubicle run of toilets upstairs in the building I'm renovating. When you flush one toilet, waste would come up in the bottom of the others in the run. We had a drain unblocking service carried out, hi pressure hose, cctv check etc. There is no blockage, so I can only assume its something else. If you flush food colouring in any of the three toilets, the water in the bottom of the other two changes colour to match. Any thoughts?
